error according printing html report
I bulid a vi to print HTML report but I have problem printing this report .
I try ever to used some example which national Instrument bulid , such as Report Generation > Text
Report, but ever in this example I couldn't print the file (HTML).
(2,656 Views)
Wisam,
Could you tell us what procedure are you following to run that example? and also what version of LabVIEW you have?
The way you have to run that example (Text Report.vi) is that when you open it, in the control that reads: "Report Type" you select HTML, and also in the control that reads "HTML Save Path" you set the path like for example "C:\test1.htm", now run it and you should have now the HTML format type report. I believe that you also have in that same directory of examples another one called : Example HTML Report Report, that one also shows how to print a report to an HTML file. Try the example you mention setting up the controls that I wrote above and it should work. If not please contact us and we can try to send you an original example and see if i
t works. You can do it by this same means or by direct contact ( www.ni.com/ask ).
Good luck!...
Nestor Sanchez
Nestor
(2,656 Views)
