error at easy excel text in stand alone
Hi all,
Receiving error -2146827284 at easy excel text in stand alone app.  This application works fine in the development environment just fine, but not in executable.  I have included the class and library in my build.  One difference is target computer is running MS office 2013 and development 2010.  Any suggestions? Image of error attached.
-Matt
Message 1 of 28
(4,554 Views)
A Google search yields useful information.
Does it occur after a certain amount of time?  If so, you may have reached the row limit for excel worksheets.
aputman
Message 2 of 28
(4,543 Views)
Occurs on the first iteration.  i have not found much information on the web.  Can you send some links please?
-Matt
Message 3 of 28
(4,540 Views)
Just a thought : http://digital.ni.com/public.nsf/allkb/C9408B9F08D711E786256F3300701D01?OpenDocument
- what's the version of report generation toolkit you have?
uday
Message 4 of 28
(4,539 Views)
I have LV 2015 and RG 2015.  I also have LV and RG 2011 on the same computer.
-Matt
Message 5 of 28
(4,532 Views)
Then it sounds like a file location problem to me due to the fact that it works in the IDE but not in EXE.  Check the path to your template file.
aputman
Message 6 of 28
(4,510 Views)
Path to template is correct because the template file loads.  Its only when i try to write to file through the excel easy text that i get the error.
-Matt
Message 7 of 28
(4,504 Views)
Are you sure you are creating exe with RG 15 vis and not RG 11, because RG 11 doesn't support office 2013.
uday
Message 8 of 28
(4,496 Views)
How do i validate that i am?
-Matt
Message 9 of 28
(4,494 Views)
How do you know the template file loads?  Does it open up on screen or are you doing error checks?  If not, don't assume that because the error pops up during the write process that the error occurred there....that it didn't occur somewhere prior to writing and was simply passed there thru wires.
aputman
Message 10 of 28
(4,487 Views)
