error at niUSRP set time.gvi
hello, i am new in labview communication and USRP
i'm trying to run mimo ofdm 2x2 in 2 usrp 2922 as Tx and usrp rio(2943) as RX
but i get error like this
first
error - 1074118627 occureed at niUSRP Set Time.gvi
possible reason(s):
a runtime or configuration error occured.
code: 1299
details: LookupError: KeyError: update_clock_source: unknown source: mimo
second
error - 1074118643 occureed at niUSRP Write Tx Data (2D CDB).gvi
possible reason(s):
packet had timestamp that was late (or too early)
please help me
thank you
(3,642 Views)
Accepted by topic author chandra.ha
Chandra,
 Thank you for posting! Looking at your two error reports, they seem to be two very different issues.
For the first one, I'd address to see if you have the correct firmware (based on your screenshots it seems like you do but just to be on the safe side). The below link has more information.
https://forums.ni.com/t5/USRP-Software-Radio/ni-USRP-Error-1074118643/td-p/3055071
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6V6SAK
In terms of the second issue, there might be a misconfiguration of the Trigger functionality. I've included more information below including sample problems to get started testing.
Ali S.
Applications Engineering
(3,606 Views)
Thank you for your reply
the problem is solved after i read niUSRP properties
thanl you
(3,593 Views)
