error at stop task.vi
hi! i am getting error while i am running my program
Error-200429 occured at DAQmx stop task.vi
i have attached my two subvis
thanks
(2,738 Views)
Hi swami1,
Thank you for posting to the NI forums.
Why are you creating so many Digital Output tasks for the same port?  I would recommend consolidating those tasks into one.
Also, try using just the Clear Task.vi instead of both that and the Stop Task.vi.  Usually this error occurs when using the Clear Task.vi, so if that doesn’t work, try using just the Stop Task.vi.
Post back with your results.  Thanks!
Ed W.
(2,692 Views)
