error buiding installer
Hi
I 'm working on labview 8 with NIDAq 741and I want to build an installer for my application but I do have the following error message during the build
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFDistCopyList_CopyItem.vi
Loading product deployment information
Reading distribution information from path: "G:\products\daq\traddaq"
*** Error: Improper function call or command line argument. (Error code -30)
*** End Error Report
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
Reading distribution information from path: "F:\"
Reading distribution information from path: "G:\"
Copying distribution 'Drivers de périphériques National Instruments - Novembre 2005' from: F:\ to: C:\Documents and Settings\Olivier\Mes documents\aircanada\labview\Acquisition Data Folder\Builds\accelerometre\ Installer\
*** Error: Windows SDK function returned an error. (Error code -12)
Done building deployment
could you explian me what does that mean and what can I do to fix this problem please ?
thank you
Olivier
(2,918 Views)
Hi ,
I also got the same errors earlier when i tried to make some executables...!
I think your DAQ driver is not installed properly,just try reinstalling the driver and then make an exe.
I think that should work.If yes let me know...!
Dinesh Kumar
Certified Labview Associate Developer(CLAD)
Don't Forget to Rate the answers.!!! You can do it in few seconds
(2,911 Views)
