error case structure with exclusions
Hi all,
As is recommended coding practice, I use error case structures in my subvis to prevent code from running when an error in occurs. However, I would like the code to operate for specific errors, say errors between values 5001 and 5010. I tried entering the specific error values into the case header, as shown in the following snapshot image, but as suspected LV wasn't happy. Namely because I entered numbers into a string-based case structure.
What's the easiest way to include/exclude specific error values from the case structure? Do I have to strip the error cluster outside the case structure, check for the value range, and create a simple true/false case structure? I would love an easier way if anyone can advise?
Thanks!
Riggy
(3,008 Views)
Hi Riggy,
unbundle the error cluster and connect the "code" value to your case structure.
Mike
(3,006 Views)
Hi Mike,
As soon as you suggested that, it seemed so obvious I can't believe I didn't think of it myself! Smiley Very Happy
Thanks!
Riggy
(3,003 Views)
