error code 14: Could not load data space type map
I get the above error when i open the example vi from NI, "event tracking" (attached) and I can't open the vi.
Not sure how to correct it.
(3,675 Views)
Hello �
What version of LabVIEW are you using? Were you just trying to open the example program from the NI Example Finder and you got the error?
I am attaching version 7.0 of the Event Tracking VI. Please let me know if you can open it.
Hope it helps!
S Vences
(3,675 Views)
I'm getting the same error but when I try and open a vi I just created yesterday.
The vi is for GigE camera viewing and the only difference between it and one that does open is that I have it set up for four camers instead of one. I saved it and closed it last night without any issues but this morning I get error code 14?
I can not open the first Event_Tracking.vi below but can open the second one if that makes any sense?
(3,321 Views)
