error code 1450 - memory mapped file
in my application I am using memory mapped files. I have three of it, the maximum size of the biggest one is 5MB. I store 64 Waveforms from a DAQ card in it.
The application runs fine, but sometimes comes an error, when I try to access the MMF. The error code is 1450, "insufficient system resources"
Is a size of 5MB too big? Should I rather create one MMF for each waveform?
(3,937 Views)
Hi mitulatbati,
which development tools are you actually using?
Which platform, libraries and so on...?
Can you post example code?
Marco Brauner NIG
(3,920 Views)
I am using LV7.1, and I call some functions from kernel32.dll and user32.dll.
In the meanwhile I figured out, why I get this error message.
I have called the "OpenFileMappingA" function to read/write memory mapped files, but I havent closed the returned handle. So I made a handle-leak in Windows...
(3,914 Views)
