error code 1620
I can't install Labview 6.1. It says "Failure to Initialize. Error Code 1620."
(2,969 Views)
This error is probably caused by the driver installation from the LabVIEW CD. I would recommend you do a custom installation and first install only LabVIEW. Then install any drivers you need from the CD. If the driver installation still gives you problems, you can download the latest driver versions from our web site:
Drivers and Updates
http://digital.ni.com/softlib.nsf/ MainPage?ReadForm&node=132010_US
Zvezdana S.
(2,969 Views)
