error code 200035
Hi everyone,
i need to control a MEM scanner with a labview program i originally developed for ordinary scanners. The problem is the MEM's can only be run at 10Hz maximum, but my pprogram gives me an error (200035) when i run it below 1000S/s. i gues it's a restriction of the pci-6110 that i'm using. Is there anyway around this? I' was thinking if i could generate an output voltage of 100hz and only use every 10th sample thast might work but i don't know how to do this.
Any suggestions greatly appreciated
Colm
using labview 7.1
(2,864 Views)
Hi Colm,
I have modified your code to run a AI task at 1000S/s, and then reduce the data that we get back so that you will have the same amount of data that you would have if I did not increase the AI sample rate. This allows the AO task to update at 10S/s so the application can still talk to your sensor.
Regards
JamesC
NIUK and Ireland
(2,850 Views)
