error code -2147192831 HypotULTRA 7850
Ive attempted to build the basic program that is given as an example when I download the driver for an Associated Research HypotULTRA 7850 Dieletric Analyzer. I countinously get this error message "-2147192831  Exception occured in ARI78XX.ARI78XX.1: ARI78XX: Instrument error detected.  Use ErrorQuery() to determine error(s). in Hypotultralabview1.vi" Here is the link for the driver and the vi. http://docs.arisafety.com/ftplink/lit/IVI%20Driver%20HypotULTRA%207800%20Technical%20Guide.pdf Its very basic and Im not sure what the problem is. The only other hardware I have is a SC6540 Matrix Scanner which basically gives the main unit more channels, from 8 to 16. Any help would be greatly apperciated.
(4,631 Views)
Issue Solved
(4,600 Views)
How did you resolve this issue..
Could you please let me know the solution....
I have been facing the same issue.
(3,847 Views)
I'm facing the same problem.
(2,670 Views)
