error code 3051
I need help fixing a problem with an error code.  The code is 3051 and happens when I try to start multsim it says The Microsoft Jet database engine cannot open the file 'C:\Multisim\Mscomp.prd'. It is already opened exclusively by another user, or you need permission to view its data.
Error Code: 3051"
I can't find anything in the support pages to help me fix this any help would be great my os is windows 98se
(3,615 Views)
Hi Allen,
This error message indicates that you have a database problem.  The first thing you should check is if you have permission to the database file.  Navigate to the install folder and you will find a “database” folder; make sure you have full access to this folder and all files inside it.  There is a knowledge base that describes this problem:
http://digital.ni.com/public.nsf/allkb/B06773CE511C7E588625720B00502B8E
Tien P.
(3,578 Views)
