error code -808
My VI is checking for several conditions, when it's true, a subVI should popup and wait for my input (press one of four buttons), however this SubVI crashes (i.e closes without waiting for my input), so I checked the error out of this SubVI and it says: error code -808, source: <append><b>Timed structure(s):</b> L110126428
What does this mean?
(5,217 Views)
From the LabVIEW Help:
−808 The given name is already being used by the following timed structure.
So, you're using the same name for another loop somewhere in your code.
(5,208 Views)
How can I access the loop's name and change it?
(5,204 Views)
Accepted by topic author Moobe
You can either do it from the loop's GUI configuration:
or you can do it on the block diagram by adding an input to the Input Node.
Again, this is all in the documentation.
Message Edited by smercurio_fc on 06-17-2010 12:52 PM
(5,192 Views)
Thanks it worked 😄 !
(5,187 Views)
