error code 9: convert files so I can use them on labview 8.0
Would someone convert these files which were created with labview 8.2.1 convert them so that I can use them with 8.0?
Message 1 of 10
(3,338 Views)
Here you are.
Message 2 of 10
(3,330 Views)
=D
Message 3 of 10
(3,325 Views)
I have the same pb than CathyC, please someone can explain how to obtain the conversion can used with labview 8.0
Smiley Indifferent.
Thank!
Message 4 of 10
(3,281 Views)
here my files :
Message 5 of 10
(3,278 Views)
Hai,
Attach all the supporting iMaq VI's.
Mathan
Message 6 of 10
(3,274 Views)
mathan wrote:
Hai,
Mathan
That isn't permitted. Imaq VI's are part of the Vision Suite for LabVIEW which is an extra cost in LabVIEW.  Either someone with Vision would have to make the conversion, or someone without could do it, but the links to Imaq would be broken, they might need to be relinked by the original poster once they open the downconverted file.
Message 7 of 10
(3,263 Views)
Here!
Message Edité par Manou le 04-23-2008 08:46 AM
Message 8 of 10
(3,261 Views)
So ..?Smiley Indifferent ! Someone could make the conversion without Imaq VI's pleaaaaaaaaase!
Message 9 of 10
(3,258 Views)
Hi Manou,
I was able to convert your files to 8.0, except that there was a file called "IMAQ Vision Example Folder.vi" which was not included. Everything else should be back into LabVIEW 8.0
Message 10 of 10
(3,221 Views)
