error code c0000374
i have  a problem with a vi from the data aquisition field. It traces graphs by using several machines(voltmeter, oscilloscope). When i execute the vi it works fine if i let it do the measurements all the way. But as i tried to test it, i executed the vi and stopped it multiple times in the middle of taking measurements on the machines. At this point labview crashes and i have to stop it. These are the details of the error:
Signature du problème :
  Nom d’événement de problème:    APPCRASH
  Nom de l’application:    LabVIEW.exe
  Version de l’application:    9.0.0.4024
  Horodatage de l’application:    4b2aa27a
  Nom du module par défaut:    StackHash_5ce4
  Version du module par défaut:    6.1.7600.16695
  Horodateur du module par défaut:    4cc7b325
  Code de l’exception:    c0000374
  Décalage de l’exception:    00000000000c6ab2
  Version du système:    6.1.7600.2.0.0.272.7
  Identificateur de paramètres régionaux:    1036
  Information supplémentaire n° 1:    5ce4
  Information supplémentaire n° 2:    5ce460cd60081fb6a52beb9f8db1bce1
  Information supplémentaire n° 3:    bd8a
  Information supplémentaire n° 4:    bd8a13faf1224b5ce603f6e14038c45a
Could you help me find a solution?
Thank you!
(5,038 Views)
@irina_tic wrote:
.. and stopped it multiple times in the middle of taking measurements on the machines....
Well, maybe you shouldn't be doing that. When you abort something that's in the middle of doing something you're not allowing whatever process it is to clean up after itself. For example, you may not be stopping a data acquisition properly, causing the hardware to be in an unstable state.
(5,035 Views)
Yes, i am aware of that, but i'm trying to put the vi on a web page and make it available to other people. And how i can't make sure that they won't stop the vi, making labview to crash, i have to find a way either to prevent it or deal with it.
(5,026 Views)
