error during writing digital output in usb-6343
hello.....
i have a trask to produce some digital waves... so i am using daq-6343 usb. for starting it, i am trying to write 1 simple value (i.e  1) to first pin of port. but i am getting error.. here i am attaching error png and vi of code... plz help me out here..
thanks & regards,
Message 1 of 17
(3,988 Views)
hello i tried some modification and i am getting different error.... plz some look into it and help me out here.
Message 2 of 17
(3,952 Views)
Hello!
Here is the solution to both your queries:
Query 1:
http://digital.ni.com/public.nsf/allkb/370BD28D3D81EB95862572D0000B1C48?OpenDocument
Query 2:
You must write to the buffer before starting the task. i.e. in the virtual channel, DAQmx Write function should come before the DAQmx Start function.
Hope this helps!
Message 3 of 17
(3,882 Views)
hey thanks for reply....
your answer realy helps me.
but now it shows error regarding buffer size.. but as per my knowledge labview itself select buffer size...
regards,
Message 4 of 17
(3,868 Views)
1. Could you please post a snapshot of the error and also the vi?
2. Is it necessary to use hardware timing? Software timed output might help.
Message 5 of 17
(3,856 Views)
i am using same vi with altered position of write and start Vi... right now i am not able to post png file...
but says error of buffer size.. expected is 2 but set value is 1.
Message 6 of 17
(3,852 Views)
continue..
No.. there is no need to use hardware time.
Message 7 of 17
(3,838 Views)
For a single point output create task, write to buffer, stop task, clear task. No need to have a hardware time for single sample.
For a waveform output, use software timing.
PFA the examples for Digital Output.
Message 9 of 17
(3,835 Views)
hey vkatre...  thanks for help.. can u repost Vi in labview 10...? that would be so gratefull.
Message 10 of 17
(3,826 Views)
