06-13-2016 03:35 AM
Hello
I'm using LV 13.0 (32) bit.
after finishing my project i decided to generate installer for our customer.
but i have faced with this error :
Application works without any problem .
I have test my project with LV13 (64 bit).
installer generated without any problem .
and I have generated many installer with LV 13 (32 bit).
I don't know why this project has problem.
06-13-2016 03:50 AM
06-13-2016 05:51 AM
As i said i can generate this project with LV 13 (64 bit)
i couldn't generate with LV 13 (32) bit.
my project attached in this reply
06-14-2016
05:02 PM
- last edited on
09-24-2026
08:38 AM
by
Content Cleaner
Hey there.
See the article linked below and try the solution there. Also see the LabVIEW 2013 Patch Details- apparently this issue was fixed in the LabVIEW 2013 f2 patch for 32 bit. From that page: "In LabVIEW 2013, including VIs from libraries that have unsatisfied dependencies cause building an installer to fail with error 1 "Error Generating Preview." Hope this helps!
Why do I see "Error Generating Preview" When I try to build an executable application or an Installer in LabVIEW 2013?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8m4SAC&l=en-US
