error handling
I would like to put a error handling VI in such subvi that contains all the custom error code and would convert the input error cluster to the corresponding error clsuter for the error code given.  Is there a better way of doing the same thing?  I am trying to convert the error cluster and pass it to the end of the program for the dialog to pop up.
Kudos and Accepted as Solution are welcome!
Message 1 of 17
(5,060 Views)
Look at the LabVIEW help for the "Error Cluster from Error Code" vi that you have in your diagram. There is a link to "user defined error codes", which allows you to build a table of custom error codes, defining the various numeric ranges allowed in LabVIEw so that you don't conflict with predefines codes.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 17
(5,047 Views)
The error ring is your friend my good man.
Message 3 of 17
(5,039 Views)
Hi, Jeff:
I'm curious - have you ever used this method (Tools»Advanced»Edit Error Codes) to integrate your error codes?  I was wondering what the pros and cons would be.
Thanks!
Bill
CLD
(Mid-Level minion.)
Message 4 of 17
(5,030 Views)
Actually No I haven't.  It is fairly straight forward though I've heard and the custom codes can be included with an installer.
I just don't write too many errorsSmiley Very Happy
Message 5 of 17
(5,021 Views)
We use custom error codes for our libraries and they are quite easy to implement. They are nice because you can give a more meaningful error message. The downside is that it is another thing to maintain. Also, the typedef for our error codes is a ring and so the value of the error rings in our code do not update automatically when you change the typedef.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 17
(5,010 Views)
Another plus for the error ring!  It integrates with the custom errors you define.
Message 7 of 17
(5,001 Views)
The error ring looks cool, but if I have a bunch of custom error codes that I want to manage using one subvi, I would have to create a case structure that contains these different error ring, since I can't put error ring in an array.  Using a case structure with the error ring.  Never used the error ring before, but would like to know more.
Message 8 of 17
(4,980 Views)
The error ring works with the customized errors.  You just need to maintain your customer error files and the ring will work automagically.  BTW, the error ring is new to LV2012.
Message 9 of 17
(4,978 Views)
cool. I will do that.
Message 10 of 17
(4,973 Views)
