error in Print Report.vi
Sorry, I had not checked the exact name. It's called NI Labview Report Generation Toolkit for Microsoft office.
Do you have one in Add/Remove programs in Conrol Panel?
If not it is really strange and in this case I would contact NI and ask them for tech support. May be tell them about my experience and you can even mention request# 399786.
Good luck,
Peter.
Message 11 of 13
(723 Views)
"Pvakh" wrote in message
news:506500000005000000D6630000-1012609683000@exchange.ni.com...
> Good luck,
> Peter.
Problem on execution of "Test Report Example.vi" or any program using
"Easy Text Report.vi".
Program tested on Windows 98 SE with both labview 6.0.2 and 6.1
installed, base NIReport VI.
Under LabView 6.1 and selecting Standard report, error -1073741819
Solution found with the help from NI support.
The solution is quite strange but it works.
Load the example and by Browse > Show VI Hierarchy select the "Font
Style.VI".
Go to diagram and change the leftmost property node "Report - Text Font"
to any other and then go back to "Text Font".
Save the VI.
After this on my computer I get another error -2147352567 on "Print
Report VI".
After some investigation and debugging with no results, I tried to do
the same thing on any property nodes in all sub VI (excluded the HTLM
sub VI).
I do not know exactly which VI is wrong , but at the end of this
operation the example was OK and so also any other test made with Text
Report.
Bugs report on NIReport Toolset for office from NI Developer Suite 2002
(February)
The word, Exel and HTML seems working fine, but again the standard
report generate error.
After many test and compare with the base version I find the error on
the Tables.Vi and again in the Font Style.VI.
In ToolSet Tables.VI there are errors in closing some automation
reference number (not easy to explain). I suggest to replace this VI
with the one from the base version. The tool set rename the base library
version to ..\vi.lib\utility\NIReport.bkp at installation.
In Font Style.VI at the exit of the program there is an Automation Open
instead of a Close operation. Replace it and save.
Posted via Mailgate.ORG Server - http://www.Mailgate.ORG
Message 12 of 13
(723 Views)
These instructions partially solved a problem with similar symptoms on my Windows 2000 PC running LabVIEW PDS 6.1. I also had to correct the Font Style.vi as per NI document 2IDB7OLD (replace an Automation Open function with an Automation Close) to completely solve the problem; before the last change, I was getting a 3005 error from the samples.
Message 13 of 13
(723 Views)
