error in build specification in project explorer (Labview 2010)
Hi
I am having problem with build my file in project explorer after install Labview 2010. Error occur stated that as attachment. I already reinstall back the software especially the ni devices. still having the same problem.
(3,276 Views)
Hi Citrusgal
Have you tried opening the VI IMAQdx.vi that is reported as bad? That might give you a better indication of what the problem is. Which version of IMAQdx do you have installed? Also, when you say that you reinstalled the software do you just mean LabVIEW or also the drives (like IMAQdx)? If you've installed a new version of LabVIEW you need to at least repair the drivers to install support for the new version of LabVIEW.
Best Regards
David
NISW
(3,251 Views)
Hi, thank you for reply.
1) I just found that there is broken wire at Imaqdx.vi under VAS, which is at dependencies of the CVS.
2)i installed Imaqdx 3.7
3)i reinstalled both Labview 2010 and also the driver..besides, i just downloaded VAS 2010 from ni and uninstalled the imaqdx and installed the imaqdx again.
Now, i am trying to get a new support imaqdx for the Labview 2010.
(3,244 Views)
Hi
Sounds like a plan. Post back how it goes.
Best Regards
David
(3,235 Views)
Accepted by topic author citrusgal
The problem has resolved after I installed the Labview 2010 sp1 patches...Thanks for replied and give some idea and opinion..
(3,186 Views)
