error in building application (error copying file)
hi i am building an application. there is one top level file but there a  lot of subvi's running in it. i am trying to build an exe of it. it comes up with the following error. Please advice and oblige.
Best Regards
sandi
Error copying files.
Source: ..\..\Program Files\National Instruments\LabVIEW 7.1\resource\cviVXDWrapper.dll
Destination: C:\Documents and Settings\SB185157\Desktop\RANDOM\builds\HSFD\My Application\data\cviVXDWrapper.dll
Librarian Path Location.vi
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1 occurred at AB_Destination.lvclass:Copy_File.vi -> AB_Source.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_FRAMEWORK.vi -> AB_CreateNewWizard_Invoke_CORE.vi -> EBUIP_CreateNewWizard_Invoke.vi -> EBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
(2,807 Views)
Stick to the original thread. Don't start a new thread for same type of questions. Please wait patiently. Somebody will surely help you.
Mathan
(2,802 Views)
