error in/error out
Hello. I want to learn to manage the cluster error in/out. Attached there is the VI that I have created.
As you can see I think that I can handle properly the error out (I can modify the status/the string etc etc)...what I want to do (but I don't know how to) is modify the error in.
I mean if i get as input -1 I saw the message in error out but i want that also the error in change his status (boolean/string/code).
Can you tell me how to do it?
Thank you
(3,766 Views)
Which error do you want in the Error In terminal.
If you want the Error Out String in Error In (where i dont find any logic) you will need to put the local variable of the Error In Control and connect it to the Error Out terminal.
(3,757 Views)
Can you be a little more clearSmiley Indifferent. I hope you can use the error constant for the type of question you have.Smiley Happy
Spoiler
(3,734 Views)
(3,713 Views)
