error in installation of setup created using application builder
sir
i have made .exe and installer using application builder
when i tried to install the setup in a system , it is showing error. the screenshot of the error is attached below.
thank u in advance 🙂 😄
(3,065 Views)
Hi thakurshubh,
I don't see any error. All I see is the standard "NI error reporting tool"…
You already have been recommended to read this plea for full words. I will recommend it again!
(3,056 Views)
sir,
it is not possible for me to send you the attachment of installer of application builder where it is showing error bcz it is of 209 mb memory.
so can you tell me the method for sending you the attachment of error?
or is there any other way to explain you the error ??
so that you can help me with the solution.
(3,031 Views)
If you have an error with your program, the show that error.
I expect that you got a error message informing you about the error, what did that message tell you?
Sending the installation program to the forum does not make any sense.
What you could do, is attaching your project and all the vi's for that project.
You could make a zip file with all the files.
(3,009 Views)
