error in writing arbitrary waveform
HI all,
I am using labview code to generate arbitrary waveform using generate multitone.vi from national instrument. and I am using average power in Power Level Type. when I run the code I have an error as mentioned in the attached photo. I was trying to google it, but I couldn't find anything helpeful. Any idea? thanks in advance
Azam
(4,059 Views)
Hi Al-rawachy
I need more details to help you with your request.
Could you please precise the NI hardware you are currently use with this issue ? And the area of your application ?
What is the LabVIEW error code ?
Is the error reproductible ? And at which frequency ?
And have you start to code from a NI example vi ?
(3,981 Views)
Hi Morandat,
Thank you so much for your reply, actually, I've solved the problem. Thanks again
(3,973 Views)
Could you please have some time to explain to the RF community your issue and its resolution ?
(3,949 Views)
HI Morandat,
Sure, I am working on RFSA NI PXIe-5663E and RFSG NI PXIe-5673E. I am using vi which belongs to the ni to generate multitone. I did a little bit of modification and I made a code to generate power and frequency sweep for these multitone using arbitrary mode . The code was working fine. Then, I integrated my code with my friend's code and I got the error in the above. We share the same GUI. I didn't notice that he is using script mode. Then, I change the generation mode to arbitrary mode and everything goes well.
I am at your disposal for any further explanation
Regards
(3,942 Views)
