error inserting activex object
We've developped a dll in Visual C that registers an ActiveX server.  Now we want to integrate this activeX server in Labview 7.1.  We get the following error message:
"error inserting activex object : No such interface supported. we tried the following step as explaine in the link http://digital.ni.com/public.nsf/websearch/4F811A9B23F1D46E862566F700615B7A?OpenDocument but doesn't work.
Does anybody know how to solve this issue?
Thanks in advance for the help.
(4,425 Views)
Are you using the ActiveX container control? As far as I know that only handles ActiveX controls and documents, not ActiveX servers. Just out of curiosity, does it work with a Visual C program?
(4,412 Views)
Correct, you'll probably need to use the Automation Open in the ActiveX palette (block diagram) instead. The front panel container is only for ActiveX controls.
(4,408 Views)
Hello Brian,
I am using a full development version of labview7.1 I cannot find the ActveX palette so cannot find the Automation Open as well, what version of labview should I use?is it possible to install drive for such application like ActiveX?
(4,395 Views)
Look under All Functions->Communication->ActiveX in the block diagram palettes. I don't remember when ActiveX was added, but it was several versions ago so you're fine with 7.1. Also, take a look at examples\comm for examples with ActiveX, such as axevent.llb and actxpp.llb.
(4,380 Views)
