error installing 488.2 v2.1 or ni-daq v7.0
Hi, I've tried installing 488.2 drivers on Win2K machine but I get an error 1603, the same happens when I try to install ni-daq. I'm using labview 6.1. Thanks for you help
JMD
(3,079 Views)
The 1603 error code indicates that there was a "fatal error". This is usually preceded by a more specific error message. Was there another message before you got the 1603s?
Naren
(3,079 Views)
no there wasn't any other error before this. I tried installing the software on another machine and it worked just fine. Thanks for the reply
JMD
(3,079 Views)
Try downloading the driver from NI's site. Also it sometimes help to copy the driver from the CD to the harddrive.
Is this the first time you installed LabVIEW on this computer?
(3,079 Views)
These are the drivers I dl from the ni website. It is the first time that I installed Labview.
JMD
(3,079 Views)
you should contact ni tech support at www.ni.com/ask
(3,079 Views)
