error message: no registered trigger lines
I was using the example within labview 7.1 under "Hardware input and output ------Daqmx ------Synchronization------Multi-function---multi-funtion-synch AI-AO.vi". I was using pci-6032e card (device 2) for input and pci-6713 card (device 1) for output.
Then this error message jumped out when I was trying to run the labview vi.
Possible reason(s):
No registered trigger lines could be found between the devices in the route.
If you have a PXI chassis, identify the chassis correctly in MAX, and make sure it has been configured properly. If you are using PCI devices, make sure they are connected with a RTSI cable and that the RTSI cable is registered in MAX. Otherwise, make sure there is an available trigger line on the trigger bus shared between the devices.
Source Device: Dev2
Destination Device: Dev1
Task Name: _unnamedTask<9>
I am using RTSI cables connecting the two devices. But I don't know how to check if this RTSI cable is registered in MAX or not. If not, how could I register it?
Zexi,
http://mypage.iu.edu/~zzhuang
(3,978 Views)
Hello Zexi,
This discussion forum post explains how to configure the RTSI cable in MAX!
Eric
DE For Life!
(3,975 Views)
Thank you for your information.
I just had trouble finding that item RTSI cable in the MAX. Later in the help, I found that I needed to use "creat new" to creat that item. Thanks very much.
(3,961 Views)
