error message when we attempt to compile an FPGA program for the cRIO
I getting the following error messages.......sofware is the latest 2015 version of labview:
Can anyone help:
(3,499 Views)
Could you upload your code so we can have a look at it?
(3,485 Views)
I'm actually a technician and just just install the software. I have just installed the latest version and when an academic tested it he go the errors i posted above.
I have attached some files that should have the code in it....hope that helps..
(3,443 Views)
(3,442 Views)
Do you see the same error when you compile a blank bitfile?
It looks like this may be a software installation error.
________________________________
Nadine H.
Certified LabVIEW Developer | Certified TestStand Developer
(3,414 Views)
