error message
i get this error after 1 time runnig this program second time i get this error. i dont know what to do.
(1,509 Views)
Hi asimanorujov,
Extend your VI to handle the error gracefully!
How do you stop your VI? Do you close/end the communication with your device properly?
Is the device in a state where it will/should respond as expected?
(1,502 Views)
So the first time it runs well forever(?) but when you run the second time you get this after exactly(?) one minute?
Is there anything special happening after 1 elapsed minute? How did you stop the first run (gracefully, abort, etc.)?
I would look for bugs in the code. Since you are only showing a picture of the front panel, we cannot help you with that. 😄
(1,471 Views)
