You need to check the full path that you are passing to the Open File+.vi. Make sure that if you are deriving the file from say the file constants such as the Current VI's Path, that if the VI is contained in a LLB, then this will be in the path name. eg ..\myLib.llb\myActualVI.vi. Therefore, you will have to strip out the llb. Similarly, if you have built an exe file, the pathname will contain the myEXE.exe.
Hope this provides some pointers. If not then post your VI, so others can help pin point your problem.
Regards
Ray Farmer
Regards
Ray Farmer
