error "Error occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->shani.vi"
Hello everyone
I get the following error when I try to link the labview to the arduino:
"Error occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr) .vi-> shani.vi"
Can anyone help?
(9,463 Views)
Your timeout value is invalid. Are you wiring a negative timeout?
GCentral
(9,452 Views)
I sent the code to a classmate, it works on his computer
So I think it might have something to do with the software itself?
Maybe I'm missing something?
(9,447 Views)
Accepted by topic author shani_efrat
Ok then, I'll take a second swing 🙂
Have you previously had any luck with VISA functions (on that computer)? Is it possible that NI-VISA isn't installed? (I'm not sure the functions would show up if they weren't, so I don't have a lot of faith in this question, but I'll go for it anyway).
GCentral
(9,443 Views)
No, this is my first project, I did not download the software
This is probably the problem
Thank you
(9,432 Views)
I believe "Arg1" is your VISA Resource.  When I wired a blank resource to the VISA Configure Serial Port (Instr).vi, it threw the same error.
Bill
CLD
(Mid-Level minion.)
(9,430 Views)
在前面板 “VISA resource name“中选择一个串口为默认值
(9,289 Views)
