error with -63193 peer to per communication ith LabVIEW FPGA
Hi, I’d like to ask for some help with peer to peer streaming. I have to stream data between two FPGA cards and whatever I tried, I always get error (-63193) when I try to invoke the P2P writer or reader in my host VI. There is no error after the openinig the FPGA vi references.
The configuration is:
PXIE 1082 chassis
PXIE 8821 controller that runs WIN10
Two 7975R FPGA modules. (From this aspect, it is not important, but both has a 5782 module)
The host VI runs on an external PC. Other functions such as signal generation, data acquisition, triggering…work perfect.
LabVIEW version: 2018 with latest drivers.
I’ve prepared and attached a very simple dummy project.
Can anyone help me to make P2P streaming work?
Certified LabVIEW Developer, Certified LabVIEW Embedded Systems Developer
(2,976 Views)
Have you tried the shipping example:
\examples\FlexRIO\Peer To Peer\Peer to Peer - Basic
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,948 Views)
Thanks for the advice. I've studied that example, and noticed that my code was basically the same. (Except of some synchronization.) And with that I had the same error.
But, there was one significant difference: In the sample code, the host is the PXI controller, and the host VI runs on that. In my code, the host was a remote PC, and so, the host vi also was a remote one (something like connecting the FPGA of a cRIO directly from a PC neglecting the RT CPU.)
So my final idea was installing LabVIEW on the PXI controller and this way, moving the host vi there too. And it worked 🙂
So, the lesson that was learnt: in PXIe systems the peer to peer communication does not work if the host vi is on a remote PC. I'll make the code look a bit nicer and upload it soon.
(2,937 Views)
Hi David,
Thanks for sharing the information!
Could you please help post your code on the page? I also met with -63193 error in PXI RT host. Do you know P2P is supported on RT OS?
(2,714 Views)
