error with web publishing tool
hello every one
I'm using web publishing tool to remote my monitor and control my font panel from a webpage. this front panel contain an Image Display and some buttons for Vision Module VIs.
the problem here, when i tried to run the main program on LabVIEW, it didn't work on webpage i opened using the link delivered to me.
and when trying to request control in the webpage there is an error messages.
so is there is any solution to this problem and mke both of them (Server - Clients) work together and switch control between them in easy way?
is it possible to set degree of control or Access in Block Diagram by Programming?
Thanks in advance
Message 1 of 13
(4,865 Views)
I see that you have one of your errors pop up in LabVIEW. It seems you're trying to get an image without starting an acquisition. This might be a LabVIEW/Vision issue first and foremost. Are you using IMAQdx Open Camera and IMAQdx Start Acquisition before you get an image? Check out the IMAQdx example "Grab.vi" to understand a little more about vision programming, or post a screenshot of your code here. Thanks!
Ravi A.
National Instruments | Applications Engineer
Message 2 of 13
(4,816 Views)
Here is an explanation of controlling access programmatically. Also, you might want to try checking the “Request control when connection is established” box in the Web Publishing Tool.
Bill E. | Applications Engineer | National Instruments
Message 3 of 13
(4,812 Views)
It is a simple code ! and I don't knw how can affect ?
Message 4 of 13
(4,806 Views)
Bill, I tried many times to open the page you suggeseted, but it can't be loaded ! ,is there any wrong with it?
Message 5 of 13
(4,805 Views)
Hi 32836,
Sorry, that the link did not work. It looks like it is working on my computer and a colleague’s computer. Not sure what the issues is but it here is the URL:
http://digital.ni.com/public.nsf/allkb/E80A7EF90F1F091986256C5B0042696C?OpenDocument
If this does not work, if you search ni.com for “Programmatically Setting the Browser Access Rights” it should come up. Also, did this VI work before publishing it to the web?
Message 6 of 13
(4,789 Views)
Thanks Bill,
It works now 🙂
and yes the VI worked befor publishing it and after publishing, it works too but alone !
only one can work either the VI or the webpage and while transition between them the previous errors appear to me
Message 7 of 13
(4,786 Views)
Excellent! Glad to hear that it works now.
Message 8 of 13
(4,779 Views)
could you please provide me with links to some NI Tutorials and webcasts for working with NI Internet toolkit to do the same as web publishing tool and share vi on web.
i searched for hem and i could not find any thing.
Thanks in avance 🙂
Message 9 of 13
(4,775 Views)
Hi 32836,
The best place for information about the LabVIEW Internet Toolkit is here. Here and here are two tutorials that should be helpful.
Message 10 of 13
(4,769 Views)
