Hi!
I am trying to collect a number of touchpoints from a controller thorugh a SCB-68 and a Daqpad-6020E. There are about ten thousand touchpoints usually in three columns and for the first 1500 everything is okay and then suddenly a bunch random numbers start accompany the expected ones as can be seen in the attached txt file called ncrtg.log. Also, in the attached vi, I do not know how to end the while loop if a certain string comes up (closed) since the loop doesn't stop and I would need help with that. J1 and RTP is commands to the controller and with RTP the controller starts "sending" out the touchpoints.
Thank you
Navid
Message Edited by Navid on 06-27-2005 06:07 PM
Message Edited by Navid on 06-27-2005 06:08 PM
