error
I have made this program but I don´t know why the cable to connect the function of reshape array and the function split number dosen´t make a good connection.
(2,700 Views)
How would you like it to work?
You want to connect ARRAY of Variant type to SPLIT NUMBER function...
Can you see the problem?
A little off topic:
Next time set proper Subject. "Error" is definitely not enough...
(2,677 Views)
Okey, thank you so much
(2,623 Views)
