error
i always have an error quiting file dialog box if i finaly decide to do  nothing (cancel)
is it a normal error (N°43) ?  have i had to intercept and kill ?
Best regards
Sébastien
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,885 Views)
Yes, the error is normal and expected. Since the File Dialog has a 'canceled' output, you can put the rest of you code inside a case statement.
(2,878 Views)
thank you
(2,865 Views)
