establish a VI to trigger data acquisition when certain conditions are met
What is the oscilloscope model? Tektronix what? Give some more spec please.
Message 11 of 24
(1,717 Views)
for time , I want carried out measurements on two hours about my current problem
is to make a record each time a click  appears and then have a report of all these clicks
Here is a more complete example of the kind of app that I want ::
https://www.rohde-schwarz.com/applications/click-rate-analyzer-for-emi-test-receivers-r-s-esu-r-s-es...
Message 12 of 24
(1,715 Views)
Did you read it? What is the model you use? 🙂
Message 13 of 24
(1,712 Views)
Message 14 of 24
(1,710 Views)
Still kind of blurry, so I can just offer some general advice, since I'm working on something similar. From the looks of it, it seems like you're measuring all the time, and want to save data to a non-volatile log when a certain event occurs, so your best bet is a polling producer-consumer architecture and a FIFO style buffer. Basically you store data in whatever size you need for your purposes (for example, last 10,000 samples) in an array, cluster or whatever, then when the event occurs, you save that buffer to a report.
Message 15 of 24
(1,704 Views)
There is a LabVIEW driver for this oscilloscope. First I would install this driver. Do it in this way:
  1. Open LabVIEW
  2. Go to "Help" --> "Find Instrument drivers..."
  3. Log in with your NI credentials
  4. Select Tektronix as "manufacturer"
  5. Type in the field "additional keywords": TDS3052
  6. Install the driver
edit: After your driver is installed, have a look what kind of DAQ options are available. Also have a look at the previous post from Daikataro, it gives you a possible way how to deal with the incoming data. You should have a Producer and a Consumer while loop. You enqueue the data arrays in the Producer, and then Examine the data in the Consumer loop. If you find a pattern, you can save the data to file.
Message 16 of 24
(1,700 Views)
 YES Exactly, that is Some Kind What I want how to do ???
Message 17 of 24
(1,696 Views)
DAIKATARO , YES Exactly, that is Some Kind What I want
how to do ???
Message 18 of 24
(1,692 Views)
Check this example on producer-consumer architecture, pretty well explained and it can help you.
https://decibel.ni.com/content/docs/DOC-2145
Message 19 of 24
(1,685 Views)
What you want to do is not really a basic LabVIEW programming. At least you should learn first the basics. The other way is to pay a programmer or if you are lucky, someone will program it for you 🙂
edit: is this a school project?
Message 20 of 24
(1,683 Views)
