eth0 on sbrio-9651 not working
I've been using the carrier board to develop/debug code for the sbRIO-9651 SOM but I´ve apparently managed to kill the Ethernet Port 0.
The problem occurred while downloading my RT code(hence also the FPGA bitfile). There could´ve been a brown-out while doing it.
Hardware:
  • sbRIO-9651
  • SN 01E7A6D8
  • Firmware version 7.0.0f0
  • OS NI Linux Real-Time ARMv7-A 4.14.87-rt49-cg-7.1.0f0-xilinx-zynq-41
Current state:
  • eth0 doesn't work, no lights, no connection
  • eth1 works fine
  • usb as well
Steps taken so far:
  • Tried both safe mode states
  • Tried re-flashing the firmware with the same version 7.0.0f0
  • Deleted and reinstalled all the software packages installed on the Labview RT
I suspect a piece of software that handles the Ethernet port 0 got corrupted in the process.
Any suggestions?
Message 1 of 1
(2,183 Views)
