ethernet address works in executable but not in labview
I use Modbus protocol over TCP-IP
The VI is a master and I have a software that emulates my modbus slave
When I run the Labview generated executable I enter my PC IP 192.168.0.1 in my configurable executable and that works fine with the modbus slave
BUT when I run my VI from LabView that doesn't works...
Do you now where is the mistake ?
Best regards.
(2,369 Views)
Wich version of LabVIEW do you use ?
You can found on the link below a library with example to use a client and server modbus on LabVIEW 8.2 (and 8.5).
http://sine.ni.com/devzone/cda/epd/p/id/4756
If you use another version, could you attach a litlle example for reproduce the problem ?
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(2,338 Views)
