ethernet/ip micrologix 1400
What is necessary to communicate with the Allen-Bradley/Rockwell micrologix 1400 controller using the LabVIEW Ethernet/IP toolkit? Is RSLinx needed? From what I can tell looking at the Micrologix 1400 "stuff" Ethernet/IP is supported in the controller, but I'm not clear as to what other support software/hardware is needed.
On a parallel path, what would be needed to talk to it via Modbus?
As always, Thanks!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,213 Views)
Hi Putnam
You should only need the LabVIEW Ethernet/Ip toolkit here is a link with some brief information.
Regarding your other question I will recommend you to create a new thread, but to answer your question it depend if you want to use the DSC module or the modbus library.
Regards
Esteban R.
(3,168 Views)
