eula file error when building distribution
I'm trying to build a distribution (package installer) but am coming across an error. It's a very long error and I've attached screenshots of it it in several snips (possibly overkill).  I am using LabVIEW NXG.
A couple things to note:
- The project executable builds successfully, but the package installer fails
- I have been able to successfully build a package installer for this exact project several times before (even as recently as 7-10 days ago).  I just made some changes and need to build a revised version.
- The project files have been moved around probably more than they should be - maybe this has something to do with it?
I currently have a support ticket being worked on but if anyone in the community has suggestions they would be greatly appreciated!
Thank you in advance!
(2,777 Views)
Accepted by topic author michelleann
Please disregard this post - seems like I can't delete it?  I updated NI Package Manager and was able to successfully build the distribution.   Problem solved!
(2,743 Views)
