eurothem control
i would like to make the controlling program for eurotherm 2404 with labview but the problem is that the driver for setpoint don't run
thank you for help
(3,174 Views)
I have used the generic Modbus Labview drivers with Eurotherms without any problems.  Can you change everything but the setpoint?  If you have a sensor break alarm, you won't be able to change setpoint.  If you can do it manually, you should be able to do it over comms.
(3,170 Views)
hi
thank you for soon reply
i can get the pv but can't change any value it return me an error message concerning the PID vi setting and the setpoint vi
(3,166 Views)
