eurotherm et24xx driver question
Hello again JHourigan,
Your help has been much appreciated, but I am still confused on one thing.  I understand the majority of the code in the images you pasted below, but one thing I am unclear on is when/where/how you program the controller to deliver a 0-10 V analog signal through output 1.  Can I see the section of code where you program this information?  For example, say a setpoint of 500K would result in an analog signal of 5.3V needing to come from output 1 to a power supply/high power diode driver -- where and how do you program this information?  I see where you tell the Eurotherm what the setpoint is.....but how does the Eurotherm then know what analog signal to send, and also from what output to send it.  If I can see that section of your code, I think my problems would be solved.
Thanks again,
Sloan
Message 11 of 14
(1,117 Views)
Sloan,
0-10V Analog is one option with which you can configure the ET24XX controller when you purchase it.  I think it is small board that is plugged in at the factory.  For instance if you were to buy a 2408 you could configure module 1 with "HZ" which is "0-10V DC heating".  There are lots of other options out there.
Once this is installed, the PID algorithm will vary the output on module 1 up to 10V in depending on the difference between the setpoint and thermocouple temperature.
Check your original documentation if you have an HZ then you have 0-10V on output 1, if you have a CZ then you have 0-10V on output 2.  If you have two outputs and one is 0-10V and the other is not then I would use the front panel buttons to configure to use the appropriate output.  Programmatically, the appopriate VIs must be in the configuration part of the VI tree.
Jeremy
Message 12 of 14
(1,113 Views)
Sloan,
I only have one output on my ET2416. So I did not have to deal with configuring which output to use in the code.
J
Message 13 of 14
(1,112 Views)
I am setting up PID values in Eutotherm 2408 (P degC, I= ms and D= ms) and its working well. however when I am reading this, its giving me different values and i dont know the unist as well. any suggestions?
Message 14 of 14
(1,070 Views)
