eurotherm rs232
Hi mike,
In the NI website there are not a 2704 drivers. Only 24XX drivers
http://www.eurotherm.com/labview/
Message 11 of 20
(1,866 Views)
Accepted by topic author new_ingenieur
Give then a try, the low-level IO at least should work for you. Naturally, if there are higher-level VIs that refer to attributes that are specific to a particular model they won't be useful.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 20
(1,859 Views)
ok thank you very much, tomorrow I 'would try to do it
Message 13 of 20
(1,852 Views)
@Dennis_Knutson wrote:
No, it's not universal at all. It is a requirement for GPIB instruments.
It's easy to get acronyms confused.  You meant it was a SCPI command.
Bill
CLD
(Mid-Level minion.)
Message 14 of 20
(1,843 Views)
I think I'm wrong, too.  I think it goes back even forther than SCPI, but I forget what it's called.
Bill
CLD
(Mid-Level minion.)
Message 15 of 20
(1,839 Views)
iEEE-488.2
Message 16 of 20
(1,829 Views)
iEEE-488.2
And since that is the GPIB standard, it turns out that you were right and I was wrong after all.
Bill
CLD
(Mid-Level minion.)
Message 17 of 20
(1,823 Views)
Yes, it existed in varying forms before SCPI. Then it was just one of the commands that HP used with their equipment. It was part of what HP brought to the party when SCPI was formalized. As I recall the two big contributors were HP and Tek.
Mike...
LabVIEW Champion
Message 18 of 20
(1,811 Views)
Oh, and thanks for being so gracious and letting me down so gently.  😉
Bill
CLD
(Mid-Level minion.)
Message 19 of 20
(1,804 Views)
Thanks  i resolved the problem by using 32XX series drivers download in NI site
Message 20 of 20
(1,778 Views)
