event callback insanity
Can anyone tell me what might be causing
such a serious error?
#Date: Mon, Jan 26, 2004 1:56:37 PM
#OSName: Windows NT
#OSVers: 5.0
#AppName: LabVIEW
#Version: 7.0
#AppKind: FDS
D:\lvworm\src\lvsource\eventoracle.cpp(370) : DAbort: event callback insanity
$Id: //labview/branches/Wormhole/dev/lvsource/eventoracle.cpp#112 $
0x00589B50 - LabVIEW + 0
0x0058A245 - LabVIEW + 0
0x0058CFDB - LabVIEW + 0
0x0040AF57 - LabVIEW + 0
0x0DDAA9C7 - tsui + 0
0x0DDA9FC3 - tsui + 0
0x0DDA1FEF - tsui + 0
0x581777B0 - teapi + 0
0x77E3A2D0 - USER32 EnumClipboardFormats + 76F
0x77E145E5 - USER32 GetDlgCtrlID + 1E
0x77E15B51 - USER32 wvsprintfW + 132
0x00B
84CA0 - LabVIEW + 0
0x00B3C46B - LabVIEW + 0
0x00C0813C - LabVIEW + 0
0x7C5987E7 - KERNEL32 SetLocalTime + 4FC
(3,070 Views)
Hi William,
I can not off hand explain this to you beyond the obvious stuff.
If you can reproduce this error at will, I suggest you share the details on how you did this.
I also suggest you report this to NI as a possible bug. I am not sure if Win NT is still supported.
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(3,070 Views)
Hi William,
You can send the error log file to NI by going to Help >> Investigate Internal Error.
Please include detailed info of how this happened (if you have any info).
Feroz
(3,070 Views)
