event case with non-user action
Hi
I'm actually using LV8.0.1.
With this and older version of LV it wasn't possible to get an event case fired without an user action. (for example by changing the value programmatically.)
Is it possible in LV 8.2?
Regards
Yves
(3,055 Views)
You can either use the Value (Signaling) property for any control (not including latched boolean) to fire Value Change events, or you can create your own events (search for the events palette and search the example finder) and register\unregister dynamically.
___________________
Try to take over the world!
(3,046 Views)
Hi tst,
thanks for your reply. Just tried to do it with the "Value Change Event".
BUT I must have missed something because it didn't worked.
What's wrong here?
Yves
(3,033 Views)
Yves,
You just missed the property node in your right-most loop.  To create a property node, right click on the block diagram control->create->property node, and then select "Value(Signaling)".  Value(Signaling) is different from "Value" in that it "signals" to LabVIEW that a change has been made, and thus an event can fire.  See the image of the code in your right-hand loop.
Hope this helps!
Message Edited by Day on 10-11-2006 09:29 AM
(3,020 Views)
Thanks for your help
If I'm right this should be the "good" version. Is there anything I have done wrong or should modify?
Yves
(2,991 Views)
