event driven wavegraph
i want to create a waveform graph/chart that is independent of time, x-axis will be based on a specific event.  i have a case structure to do this.  and is plots when that case sturucture is true, but the interval is based on time so the plots are not uniform.  how do i make the intervals based on the event too?
(3,044 Views)
Hey bweiss90,
I'm not sure, if I understand it correctly, but check out the appended VI.
Maybe this helps.
CMW
(3,025 Views)
It looks like you need an XY Graph, you can check out the examples to see if there's something similar to what you need.
(3,023 Views)
If you need a non-uniform distribution on the x-axis, you should use the XY Graph.
Norbert
Norbert
Expert: Geometry
(3,022 Views)
