event edge trigged counter in software
How can I create an event edge trigged counter in software? The counter
frequency is max 10HZ
I am using Labview 7.1
Looking forward for some suggestions
kas
(2,590 Views)
Hi kas there are several options for doing this you can find several VI including a express vi in the WaveForm Monitoring Panel, or in the Signal processing channel. One that can be particularly useful is basic level  trigger detection .
This one has an option to tell you if a trigger was detected. Simply you can count this and the reset it to wait for the next one
Benjamin C
Principal Systems Engineer // CLA // CLED
(2,583 Views)
