event handling
Is there a post that explains event handling. Basically, I want to open a path and once that path has been open, it goes through a series of steps to calculates the number of characters in that file. In C++, I can do it at any time. I want to do the same thing in labview. I can do it in a while loop, but I will be stuck in that loop until it spots a file path. Is there a way I can do it without using a while loop?
Message 1 of 8
(4,352 Views)
I made a commented example for you.
Hope that helps,
Paulo
Message 2 of 8
(4,345 Views)
Does labview 6.1 have this option? Where is the event structure located in labview?
Message Edited by Newguy100 on 09-30-2005 09:19 AM
Message 3 of 8
(4,343 Views)
I think that they came with version 6i, so you must have them in 6.1.
But I'm not completely sure about this.
Message 4 of 8
(4,336 Views)
How do you access it cuz in labview 7.1 it keeps saying "object not found"
Message 5 of 8
(4,333 Views)
That's very strange.
I downloaded it and it works here.
I made screen shots of the 3 frames.
Message 6 of 8
(4,331 Views)
Here is what i get:
In case you can't read what it says
"Object not found. The object might exist in a different palette view or might not be supported on the currently selected"
Message Edited by Newguy100 on 09-30-2005 09:40 AM
Message 7 of 8
(4,330 Views)
Please don't post bmps, they are too big.
I don't understand your error, I used a stop buuton and a path control.
Anyway I created new objects out of them and I'm sending it all to you, maybe now it will work.
Paulo
Message 8 of 8
(4,320 Views)
