event structure and radio buttons
The Mac and Windows versions have been pretty well synced since version 3 or 3.1.  Versions 2.2.1(Mac)  and 2.5 (Windows) were not.
I recall the event structure in LV 6 for the Mac. It might have been 6.1.
Lynn
Message 21 of 27
(1,894 Views)
I'm pretty sure they're right about the Event Structure.  I'm also pretty sure it doesn't really matter now. You know you have it now.
With the application you have, what's preventing the inner loop from completing?  I wouldn't expect a wait to have anything to do with it finishing.  What is supposed to make it stop?
Message 22 of 27
(1,873 Views)
Grant Johnson wrote:
"I start all my projects with the JKI state machine. If you haven't tried it then I suggest you try it out. "
This is interesting.  I will try it out.  What is the fee for a license?
Message 23 of 27
(1,857 Views)
Here is the link for the JKI state machine.  There is no fee for using it
http://jki.net/state-machine
Message 24 of 27
(1,851 Views)
No fee for using the JKI state machine.
Grant M. Johnson
Project Engineer
LECO Corporation
Message 25 of 27
(1,824 Views)
I've used the JKI state machine a little bit, but I find it hard to stick to their "best practices". They recommend running multiple states through the "macro states", and not to generate new states otherwise. In most of my test applications the next state often depends on some parameters and needs to be figured out, so if I have a test to run in a state machine, I still need to run it in a parallel loop.
Thus, the JKI state machine is used for handling UI events mostly. It does a fine job of this, but I don't think the sophistication is necessary.
edit: PS: here are the best practices I was referring to: http://blog.jki.net/products/state-machine/jki-state-machine-best-practices/
Message 26 of 27
(1,810 Views)
Their best practices are there because of overall pros and cons of doing something a particular way.  I'd recommend trying to stick with them, but if they just don't work for you, then do your own thing.  It's open source BSD and you're welcome to develop code any way you like.  So if each state can enqueue a new state then that is your design choice to make.
This is one of their best practicies that I have a hard time sticking to as well, but I know how much effort one method is, and how much difficulty later another method will give me.
Message 27 of 27
(1,740 Views)
